viscount45
Apr 28, 2015Aspirant
A6100 on Windows 10
I tried installing in Windows 8 Compatibility Mode but the PC cannot detect the device. Anyone know of a temporary fix until final release of Win10 and drivers are made available? Thanks, all.
sban
Oct 03, 2015Tutor
I did something really idiotic.
I had used the workaround as described by RH/pratyushpks and got my A6100 to work on Win 10. But then by mistake updated the driver from Device Manager! Now the moment I plug in the A6100 everything breaks down (i.e I get the new BSOD screen with 'Your PC ran into a problem...' message followed by Windows repairs options etc). When I unplug the A6100 I can normally use Win 10 again.
My question is how do I uninstall the corrupt driver and follow RH/pratyushpks's workaround again without plugging in the device? I do not have Genie installed.
Ashamedly yours.
RH
Oct 03, 2015Tutor
system restore should work if you are uable to uninstall whatever is causing this prob?
