becky1040
Jan 30, 2020Follower
A6100 software for macOS High Sierra
So far all I can find on site is Win applications. Is there a software download for a macOS?
michaelkenward
Jan 31, 2020Guru - Experienced User
The last time I looked, the only USB wifi adapter that supported MacOS is still broken because Netgear is taking its time over updating it for the newest MacOS.
It has promised an update, but that was a month or so ago.
Solved: Re: compatibility macos catalina - NETGEAR Communities
