Josh-Stout
Jan 23, 2018Aspirant
A6100 username and password protected wifi
The wifi at my College is protected by a username and password specific to me. After swapping the hard drive on my laptop something went wrong with how I get wifi and I needed a wifi adapter. In the ...
michaelkenward
Jan 24, 2018Guru - Experienced User
Doesn't Windows 10 have a connect option that brings up the SSID and password? Mine does.
It should show you the local networks available. Pick the one you want and bingo.
- Josh-StoutJan 24, 2018AspirantSince my wifi antenna is fried or something like that it will only run through the genie. When I pull up my wifi from the computer there are no networks available.
- michaelkenwardJan 24, 2018Guru - Experienced User
Sorry. I don't understand that. If the antenna is fried, how do you expect to connect to the wifi?
Surely Windows can see networks available to the A6100? It does here.
