Tiffanys61
Jun 06, 2015Aspirant
A6100 Wifi Usb mini adapter -connectioning to Fetch Tv
Hi
Was told that if I purchases this product that i could place in the usb port on fetch tv box and it would connect to my wireless modem.
Unable to connect it not sure what I am doing wrong.
Cheers
CK:)
- Babylon5NETGEAR Employee RetiredIf the Fetch TV box does not include the appropriate driver software for the A6100 it will not work.
- Tiffanys61AspirantSo what would i use then?
- fordemMentorThat question should be asked at Fetch TV tech support - the answer is going to be determined by what USB devices their box supports - by what it has the drivers for.
