cssaus
Nov 11, 2018Aspirant
A6100 Wifi USB Mini Adaptor - Increase connection speed
Just installed an A6100 WIfiFi USB mini adapter and connected by 5Ghz to my WNDR4500 adapter. The connection is running a 150mbps. I thought by connecting to 5Ghz I ought to be able to get a higher c...
Blanca_O
Nov 13, 2018NETGEAR Employee Retired
Hi cssaus
Welcome to NETGEAR Community!
What is your subscribed speed? Expected speed?
What is the speedtest result when connected to 2.4GHz?
Blanca
Community Team
- cssausNov 15, 2018Aspirant
The connection speed on the 5Ghz channel is 150Mbps. When I connect on the 2.4Ghz channel I see 72.2Mbps. These are the speeds I seen when I go into the Network & Sharing centre & click on the wifi adapter connection.
I was wondering how to achieve the 433Mbps on the 5Ghz channel? I have downloaded and installed the latest drivers. The laptop with the A6100 is within 2 metres of my Netgear WNDR4500 router.
- Blanca_ONov 18, 2018NETGEAR Employee Retired
Hi cssaus
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- Blanca_ONov 15, 2018NETGEAR Employee Retired
Hi @cssaus
I think you are referring to the link speed. The adapter is dependent with the router. Can you access the router settings page and check the mode?
Blanca
Community Team
