Plezntlyvicious
Mar 16, 2018Follower
A6100 wireless adaptor and xbox one
I have no idea what I'm doing. My husband bought this to hopefully help boost oyr wifi signal to our xbox one. Did we buy the wrong thing?
michaelkenward
Mar 17, 2018Guru - Experienced User
If the idea is to plug the A6100 into the XBox, then I fear that it is indeed the wrong thing.
Those wifi adapters are for Windows PCs.
If the XBox already has its own wifi capability, then you need something between the source of your wifi and the Xbox to beef up the wifi signal.
Something from this stuff:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
