Tiako's avatar
Tiako
A6150, installation in MAC OS doesn't work
I followed the procedures from Manual, downloaded software for MAC OS installation and then is asks to restart computer.
After i restar, i connect adapter to USB port but the N Icon is not show ins mac's menu bar.
I don't understand why the procedure of the manufacturer doesn't work.
  • Blanca_O's avatar
    Blanca_O
    Jan 13, 2020
    Hi mariogaucher
    Its has been a while since Apple started phasing out 32bit apps. MacOS Mojave was the last to support 32bit apps. Engineers advised that A6150 will be compatible with macOS Catalina by Q1 2020.
    Blanca
    Community Team
  • I figured out after some time that the icon appears on the top of the screen, in top bar, and not in the bottom bar. There is also no icon available under apps.
    • mariogaucher's avatar
      mariogaucher
      Hi!
      was this intalled on macOS Catalina (10.15)?
      I'm looking to buy the same adapter for my old MacBook... and would like to make sure it works in Catalina.
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi mariogaucher
        Blanca
        Community Team
