Marco21
Dec 15, 2019Follower
a6150 linux
Hi all,
I am thinking about buying an A6150 wlan-adapter.
Is it working (out-of-the-box) under linux (eg. Fedora or Ubuntu) ?
Regards
Marco
- Tom444Apprentice
Some poking around I've found...
https://www.raspberrypi.org/forums/viewtopic.php?t=241593
Not an out of box solution.
There a couple of other threads within that site on how to get it working.
- Tom444Apprentice
In regards to Linux support I would start in the reverse.
Look to see what Adaptors others are using (and Supported) then make your choice.
It really comes down the chipset as Netgear doesn't make their own.
So the 6150 should be a Realtek RTL8812BU
