Morte
Sep 16, 2015Initiate
A6200 drivers double installed. Cannot uninstall because of looping error.
So I've tranfered to Windows 10 as of late and have been trying to get the drivers for it. When trying to install it'll tell me I need to uninstall the standalone, then suddenly it starts running...t...
JamesGL
Sep 29, 2015NETGEAR Employee Retired
Hi Jendrik,
Please remove the NETGEAR folder under program files and check if you can uninstall it.
JamesGL
Community Team
Jendrik
Sep 30, 2015Guide
I con not remove it, same result as before
- JamesGLOct 02, 2015NETGEAR Employee Retired
You may need to check the registry of your computer. This might be a problem with the registry.
Regards,JamesGL
Community Team
- JendrikOct 04, 2015Guide
I did that and could install the Win10 driver now. But sadly the adapter keeps disconecting.
Is the adapter damaged? Or could there be another reason this keeps happening?
