Dugite
Aug 04, 2015Guide
A6200 timing out Windows 10
Hi All, hope I'm not starting a new thread, surely I can't be the only one here with this issue. After upgrading (???) to WX I have found that my WiFi Network icon gets a red X on the top left hand...
Babylon5
Aug 04, 2015NETGEAR Employee Retired
There are a few people in this thread who have had some success;
Dugite
Aug 04, 2015Guide
Yep,
read those threads, but their problem is not the same. They are saying they can't connect at all. I'm saying that I can connect but after about an hour of activity, my internet just dies, because WiFi just stops working, At the moment the ONLY way I can fix it is to remove the USB WiFi device, A6200 and reinsert it, windows finds it, logs on and is happy for another hour...
- Babylon5Aug 04, 2015NETGEAR Employee Retired
OK, well that’s strange, seems like some kind of power-save option maybe, is it always precisely an hour or is it perhaps related to the volume of data passed?
- DugiteAug 04, 2015Guide
I wish I could say for sure, no idea how to time it, but tonight 3 times already, the only solution is to unplug the USB and plug it back in, connects immediately no problems
- jeffreyh51Aug 04, 2015Guide
Hi. Had to jump in here, as I have the exact same problem.
Looks to me as though it might be data volume related, as I have scheduled backups that commence at 3 in the morning, and my issues arise when I find an incomplete backup when I check it in the morning. During the day, I have few problems with the connection, and mine doesn't seem to timeout at any particular interval, but DOES time out on occasion. I actually had not considered the data volume until you mentioned it.
I'm using the .35 beta drivers that were posted on the support page a looooong time ago on an A6200.
