Dugite
Aug 04, 2015Guide
A6200 timing out Windows 10
Hi All, hope I'm not starting a new thread, surely I can't be the only one here with this issue. After upgrading (???) to WX I have found that my WiFi Network icon gets a red X on the top left hand...
Dugite
Aug 04, 2015Guide
Yep,
read those threads, but their problem is not the same. They are saying they can't connect at all. I'm saying that I can connect but after about an hour of activity, my internet just dies, because WiFi just stops working, At the moment the ONLY way I can fix it is to remove the USB WiFi device, A6200 and reinsert it, windows finds it, logs on and is happy for another hour...
Babylon5
Aug 04, 2015NETGEAR Employee Retired
OK, well that’s strange, seems like some kind of power-save option maybe, is it always precisely an hour or is it perhaps related to the volume of data passed?
- DugiteAug 04, 2015Guide
I wish I could say for sure, no idea how to time it, but tonight 3 times already, the only solution is to unplug the USB and plug it back in, connects immediately no problems
- jeffreyh51Aug 04, 2015Guide
Hi. Had to jump in here, as I have the exact same problem.
Looks to me as though it might be data volume related, as I have scheduled backups that commence at 3 in the morning, and my issues arise when I find an incomplete backup when I check it in the morning. During the day, I have few problems with the connection, and mine doesn't seem to timeout at any particular interval, but DOES time out on occasion. I actually had not considered the data volume until you mentioned it.
I'm using the .35 beta drivers that were posted on the support page a looooong time ago on an A6200.
