Dugite
Aug 04, 2015Guide
A6200 timing out Windows 10
Hi All, hope I'm not starting a new thread, surely I can't be the only one here with this issue. After upgrading (???) to WX I have found that my WiFi Network icon gets a red X on the top left hand...
Dugite
Aug 30, 2015Guide
"Is there anybody out there???, just nod if you can hear me..... Is there any one at home???"
It's not like windows 10 has only JUST been released, I mean beta testers and developers have had it for a long long time now.
What's happening with this expensive paper weight I have purchased called a Netgear A6200 WiFi USB Adapter, I purchased it party because the brand name "Netgear" was supposed to be "OK"
JamesGL
Sep 03, 2015NETGEAR Employee Retired
Hi All,
I would like to ask the following information.
1. Is the Windows 10 install a fresh install or an upgrade?
2. If it is an upgrade, what was the previous OS prior to upgrade?
3. If it is an upgrade, did you encounter intermittent connection as well with the previous OS?
4. What is the processor used in your PC?(i.e Intel/AMD)
JamesGL
Community Team
- DugiteSep 03, 2015Guide
Mine was an upgrade from WX7 Pro, no connection issues prior to upgrade Intel chip set giggabite board
