douga54
Mar 04, 2016Star
A6200 WINDOWS 10 DRIVER ISSUES
So I opened a new case with Netgear since I could never get an answer the first time. I simply described the problem and asked for help. See below for the conversation. It's completely unhelpful a...
JamesGL
Mar 07, 2016NETGEAR Employee Retired
Hi Douga54,
Please install the Windows 10 driver first for A6200 before loading the Windows 10 software.
http://downloadcenter.netgear.com/en/product/A6200#searchResults
- douga54Mar 07, 2016Star
Does this driver also support Windows 7 or do I have to download hte Windows 10 package and not run setup until after the new driver is installed? Thanks.
- JamesGLMar 08, 2016NETGEAR Employee Retired
Hi douga54,
It supports as well Windows 7.
- douga54Mar 12, 2016Star
I intend to update the driver now, but given all the issues i want to be sure I know what I'm doing. The current driver under Windows 7 works fine with encryptionover my wifi network. The beta driver I tried when I first tried to upgrade to Windows 10 would not accept my encryption key. I need to know that this driver (V1.0.0.26-1) will support encryption under both Windows 7 and 10. I would appreciate your response. Thank you.
