douga54
Mar 04, 2016Star
A6200 WINDOWS 10 DRIVER ISSUES
So I opened a new case with Netgear since I could never get an answer the first time. I simply described the problem and asked for help. See below for the conversation. It's completely unhelpful a...
douga54
Mar 07, 2016Star
Does this driver also support Windows 7 or do I have to download hte Windows 10 package and not run setup until after the new driver is installed? Thanks.
JamesGL
Mar 08, 2016NETGEAR Employee Retired
Hi douga54,
It supports as well Windows 7.
- douga54Mar 12, 2016Star
I intend to update the driver now, but given all the issues i want to be sure I know what I'm doing. The current driver under Windows 7 works fine with encryptionover my wifi network. The beta driver I tried when I first tried to upgrade to Windows 10 would not accept my encryption key. I need to know that this driver (V1.0.0.26-1) will support encryption under both Windows 7 and 10. I would appreciate your response. Thank you.
- JamesGLMar 14, 2016NETGEAR Employee Retired
Hi douga54,
The encryption should work with the latest driver.
- mondenathJun 21, 2016Prodigy
i am having different issues. My adaptor wont connect in 80mhz only on 40mhz which is low connection rate of 270mbs I only fall back 1 bar signal as the r7000 is in next room in between a concrete wall.
My query here is only 1/3 rd connection rate is very bad and i didnt extpect this.
