Lamperino's avatar
Lamperino
Follower
Jun 20, 2017
A6210 - AC1200 High Gain WiFi USB Adapter — 802.11ac Dual Band USB 3.0 disconnects from USB
I was given this adapter by a friend who said they'd had no previous issues with it, and I was quite happy with it until I actually ran into a problem with it. Periodically, the adapter causes whatev...
  • JamesGL's avatar
    Jun 26, 2017
    Hi Lamperino,
    Can you try to install it on a different Windows 10 computer and check if the same problem.
