djsomers's avatar
djsomers
A6210 - AC1200 High Gain WiFi USB Adapter — 802.11ac Dual Band USB 3.0
I am on my 2nd A6210 and the replacement adapter is having the same issues as the original one I purchased. in late September. To explain my issue: I upgraded to Windows 10 in July. I have a HP Envy...
  • JamesGL's avatar
    JamesGL
    Nov 15, 2016
    Hi djsomers,
    The speed still depends on the what the router or the modem provides. If the modem/router can only get 100Mbps from ISP then most likely the adapter can get upto 100Mbps or less depending on the environment.
    JamesGL
    Community Team
