djsomers
Nov 01, 2016Aspirant
A6210 - AC1200 High Gain WiFi USB Adapter — 802.11ac Dual Band USB 3.0
I am on my 2nd A6210 and the replacement adapter is having the same issues as the original one I purchased. in late September. To explain my issue: I upgraded to Windows 10 in July. I have a HP Envy...
- Nov 15, 2016
Hi djsomers,
The speed still depends on the what the router or the modem provides. If the modem/router can only get 100Mbps from ISP then most likely the adapter can get upto 100Mbps or less depending on the environment.
JamesGL
Community Team
djsomers
Nov 23, 2016Aspirant
Thanks James! Hopefully TWC/Spectrum won't lower their Internet speed. Customers would really get upset if speed was downgraded.
