mattstru's avatar
mattstru
Follower
Oct 24, 2016
A6210 - Code 10 after every restart; Need to unplug and plug back in every time (Windows 10)
Hey all,   My A6210 Wifi Adapter seems to work great. Drivers were installed without issue and all. I'm running into one problem though. Everytime I restart my computer or wake it up from sleep mod...
  • JamesGL's avatar
    Oct 30, 2016
    Hi mattstru,
    At times your network adapter gets disabled after resuming from sleep mode (wake up from sleep), in case of wireless adapters, sometimes it may not re-establish the wireless connection.
    1. In Control Panel, click System and Security, then Device Manager. Right-click the network adapter (that keeps getting turned off), and select Properties.
    2. Now head over to the Power Management tab, uncheck the option that says “Allow the computer to turn off this device to save power", and click OK.
    JamesGL
    Community Team
