mattstru
Oct 24, 2016Follower
A6210 - Code 10 after every restart; Need to unplug and plug back in every time (Windows 10)
Hey all, My A6210 Wifi Adapter seems to work great. Drivers were installed without issue and all. I'm running into one problem though. Everytime I restart my computer or wake it up from sleep mod...
- Oct 30, 2016
Hi mattstru,
At times your network adapter gets disabled after resuming from sleep mode (wake up from sleep), in case of wireless adapters, sometimes it may not re-establish the wireless connection.
1. In Control Panel, click System and Security, then Device Manager. Right-click the network adapter (that keeps getting turned off), and select Properties.
2. Now head over to the Power Management tab, uncheck the option that says “Allow the computer to turn off this device to save power", and click OK.
JamesGL
Community Team
JamesGL
Nov 02, 2016NETGEAR Employee Retired
Hi mattstru,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
