gbjbasdw
Apr 06, 2016Aspirant
A6210 & Windows 10 - Does driver 1.0.0.34 fix all the problems I have read about ?
My time is too short to mess around with different drivers/solutions. One question - does the A6210 adapter work with Windows 10 32/64 bit PROPERLY using driver version 1.0.0.34 ? I'm not int...
JamesGL
Apr 11, 2016NETGEAR Employee Retired
Hi gbjbasdw,
I've been using an A6210 adapter and it works fine on my Windows 10. May I know what issue do you have with the adapter?
- gbjbasdwApr 14, 2016Aspirant
I don't have any issues with the adapter becuase I don't have one.
I am trying to establish if I will have any of the problems others seem to have encountered BEFORE I buy one.
- MentallyRichApr 24, 2016Aspirant
Sadly no. My connection after a while will drop, which is most annoying when playing a game online.
To get around this I uninstalled the netgear driver and just used the one windows 10 finds for it but because that isn't the proper driver it doesn't take advantage of the features of the adapter. I went from about 110mbps to about 10mbps with this driver and my home connection is 200mbps. The annoying thing is I bought this adapter so I could get the best speeds. I'm presuming this is simply a driver issue and they aren't bothering to fix it.
Definitely don't buy this until they fix the connection drop issue as it's extremely annoying!
- JamesGLApr 25, 2016NETGEAR Employee Retired
Hi MentallyRich,
Did you use the standalone driver or the driver with genie? If it is the driver with genie, please try the standalone driver.
- MentallyRichApr 26, 2016Aspirant
I reinstalled the standalone driver yesterday and so far my connection hasn't dropped. I did notice though that as part of a windows update this month they have improved network connectivity so maybe it was a problem with windows 10 and not the netgear driver.
