gbjbasdw
Apr 06, 2016Aspirant
A6210 & Windows 10 - Does driver 1.0.0.34 fix all the problems I have read about ?
My time is too short to mess around with different drivers/solutions. One question - does the A6210 adapter work with Windows 10 32/64 bit PROPERLY using driver version 1.0.0.34 ? I'm not int...
DavidR1234
May 14, 2016Aspirant
OK I gave up in teh end and connected to my network cable.
Then i found something very insteresting on this website.
I read that the chip insde the antennae is actaulay not a net gear chip. it is a MediaTek, Inc.chip. From here I was directed to teh media tek website to download the driver IS_Setup_ICS_011916_1.5.39.173.exe. This is detailed within the community here:
The driver is here:
http://www.mediatek.com/en/downloads1/downloads/usb/
I have uploade the driver to my PC and unhooked the cable and touch wood it has worked OK since ysterday evening until now. As i have a NAS the previous solution was not goung to work as iti is networked via cable. I would have had to get a gigbyte box to add extra items to my routers sender to make this work.
I will update on my progress with this driver. if it is pap then i will ditch the whole thing and have a go at the good friend who promised me Netgear was a very good make because Sky Broadband use them.
