gbjbasdw
Apr 06, 2016Aspirant
A6210 & Windows 10 - Does driver 1.0.0.34 fix all the problems I have read about ?
My time is too short to mess around with different drivers/solutions. One question - does the A6210 adapter work with Windows 10 32/64 bit PROPERLY using driver version 1.0.0.34 ? I'm not int...
DavidR1234
May 13, 2016Aspirant
I can confirm that I can now no longer access teh internet using wifi either on atheros or netgear. literally after i posted teh last message that was it. I have resorted to using the nextwork plug in order to write this post. either this crappy piece of junk caused the issue or Windows 10 did. I can say though that the antennae appears to be dead as a preverbial dodo!
OldmanRick
May 17, 2016Aspirant
I had to revert back to windows 7 professional. That was the only way to get the A6210 with update 1.0.0.34 to work. After trying everything, it appears to be a windows 10 problem rather than a netgear problem in my humble opinon..
- PlattfishMay 17, 2016Guide
Then Netgear shouldn't advertise their products as being compatable with Windows 10. That's literally false advertising. Windows 10 works just fine for me in EVERY regard except my crummy 6200, so I'm not inclined to have much sympathy for Netgear at this point.
