dfruman
Feb 18, 2016Follower
A6210 Adapter Crashes Windows 10
So this is an odd problem that I've had no luck figuring out. I've just reinstalled Windows 10, and prior to this I had no problems with the adapter. But now, if I try to install Netgenie via CD, o...
Bowser93
Mar 20, 2017Aspirant
I have tried everything but either the adapter crashes my comuter or the installation software won't find it!
- aalexandrebetaMar 20, 2017Master
Was it a clean Win 10 install or a Microsoft forced update?
- realdead_manMar 21, 2017Apprentice
Was it a "BAD_POOL_something something error?
If so, I get/got it too.
- Bowser93Mar 22, 2017Aspirant
Yes it was a "BAD_POOL_" error or something.
It was a clean win 10 installation.
I returned the product and got another one from another brand. Now it works fine.
- VE6CGXApr 13, 2017Master
When you install it very first time, wait until the drover software asks to plug it in. Also make sure you dn't have any old traces of the adapter.
Also check the adapter through device manager to make sure the status is normal.
