dfruman
Feb 18, 2016Follower
A6210 Adapter Crashes Windows 10
So this is an odd problem that I've had no luck figuring out. I've just reinstalled Windows 10, and prior to this I had no problems with the adapter. But now, if I try to install Netgenie via CD, o...
aalexandrebeta
Mar 20, 2017Master
Was it a clean Win 10 install or a Microsoft forced update?
realdead_man
Mar 21, 2017Apprentice
Was it a "BAD_POOL_something something error?
If so, I get/got it too.
- Bowser93Mar 22, 2017Aspirant
Yes it was a "BAD_POOL_" error or something.
It was a clean win 10 installation.
I returned the product and got another one from another brand. Now it works fine.- TugBot99Apr 03, 2017Aspirant
Best thing you did was take it back and get another brand.
- JamesGLApr 09, 2017NETGEAR Employee Retired
Hi All,
Please try using the latest driver.
https://kb.netgear.com/000037991/A6210-Software-Version-1-0-0-36
