dfruman
Feb 18, 2016Follower
A6210 Adapter Crashes Windows 10
So this is an odd problem that I've had no luck figuring out. I've just reinstalled Windows 10, and prior to this I had no problems with the adapter. But now, if I try to install Netgenie via CD, o...
Bowser93
Mar 20, 2017Aspirant
I have tried everything but either the adapter crashes my comuter or the installation software won't find it!
VE6CGX
Apr 13, 2017Master
When you install it very first time, wait until the drover software asks to plug it in. Also make sure you dn't have any old traces of the adapter.
Also check the adapter through device manager to make sure the status is normal.
