dml50
Oct 18, 2017Aspirant
A6210 adapter not found
I bought this yesterday as it is supposedly compatible with Windows 8. It says adapter not found yet it shows up in my Device Manager. Since I cannot connect to the internet on that computer I cannot...
michaelkenward
Oct 19, 2017Guru - Experienced User
Software installed?
There is a manual and other stuff for the 6120 somewhere at the end of this link:
>> Click here >> A6210 | Product | Support | NETGEAR << Click here <<
- dml50Oct 19, 2017Aspirant
Yes I did install/reinstall the software several times infact and also for stand alone.
BTW thank you for the link.
- dml50Oct 20, 2017Aspirant
Well I printed out the whole manual and followed and it still isn't found so I am giving up and returning it to the store and getting another brand
- michaelkenwardOct 20, 2017Guru - Experienced User
Where do you see this "adapter not found" message? Windows?
Another device may not be any better if there is an issue in your Windows configuration.
After installing from the cd and I plug in the adapter it searches and searaches and then says adapter not found. The adapter does show up when I check the system for plug ins but with an exclamation .
