dml50
Oct 18, 2017Aspirant
A6210 adapter not found
I bought this yesterday as it is supposedly compatible with Windows 8. It says adapter not found yet it shows up in my Device Manager. Since I cannot connect to the internet on that computer I cannot...
michaelkenward
Oct 19, 2017Guru - Experienced User
Software installed?
There is a manual and other stuff for the 6120 somewhere at the end of this link:
>> Click here >> A6210 | Product | Support | NETGEAR << Click here <<
dml50
Oct 20, 2017Aspirant
Well I printed out the whole manual and followed and it still isn't found so I am giving up and returning it to the store and getting another brand
- michaelkenwardOct 20, 2017Guru - Experienced User
Where do you see this "adapter not found" message? Windows?
Another device may not be any better if there is an issue in your Windows configuration.
- dml50Oct 20, 2017Aspirant
After installing from the cd and I plug in the adapter it searches and searaches and then says adapter not found. The adapter does show up when I check the system for plug ins but with an exclamation .
Windows then.
You could try removing it in device manager.
It might also be worth telling device manager to show hidden devices – these will show up as "greyed out" entries – and then remove those.
Do all that with the USB device removed.
Have you tried putting the thing into different USB ports? Windows will try to install for each port. Maybe one will work.
