zab
Mar 16, 2016Aspirant
A6210 ADAPTER ON LINUX UBUNTU
How can I install the wifi adapter on Ubuntu?
FlauntingFlamer
May 04, 2016Initiate
I tried some terminal commands from youtube and had no luck but when I found Github the problem was solved. Obviously you need a connection. Once these run, reboot and go to network settings There you will have the option of using your old wireless or the new usb dongle.
The commands are
$ git clone https://github.com/jurobystricky/Netgear-A6210
$ cd Netgear-A6210
$ make
$ sudo make install
"One man's nectar is another man's sour grapes."
-Flaming Flamer 2016
