dhaberle
Apr 29, 2016Follower
A6210 adapter will not install drivers
I am trying to install my Netgear A6210 adapter and had the Genie up and running when it asked if I would like to download the latest driver. On completion of the download my genie no longer works, t...
TechKitten
Apr 30, 2016Aspirant
Well, try uninstalling the driver from Add/Remove Programs, then using the CD, re-install, and DON'T update the driver until the bugfix comes out, and, try to do the update with the same card on another PC (Running Vista or XP or 8) and see if it is just a flaw with your PC, or if the software is flawed itself.
- Mereana05Jul 28, 2016Aspirant
Hi there - I've had the issue as the person above. I went to Add/Remove programs and uninstalled the adaptor. I've restarted my desktop and gone to reinstall it using the CD. The SAME errors have come up AGAIN! Please help!
- JamesGLJul 28, 2016NETGEAR Employee Retired
Hi All,
If you are getting error message 1605 and 1628 during installation or uninsstalling the device, please contact support and indicate the error message that you are getting.
JamesGL
Community Team
