ceven
Apr 27, 2023Aspirant
A6210 Constant Disconnecting
Netgear A6210 Wifi Adapter in USB 3.0 port Windows 10 Pro version 21H2 Specs too good to be relevant whatsoever Constant disconnecting (USB sound) and disconnecting when attempting speedtest ...
btev
Oct 15, 2023Aspirant
I tried all those things as well and eventually just uninstalled the device from the system (with the delete software box checked) and restarted the computer and suddenly it started working again. Not sure why, and it's no longer even listed under Network Adapters but that's what worked for me.
michaelkenward
Oct 18, 2023Guru - Experienced User
Goods feedback.
It could be that uninstalling the device removed the existing USB drivers and a hidden set kicked in, or you have found that Windows comes with native drivers that work for this USB adapter.
