eleon's avatar
eleon
Follower
Feb 13, 2017
A6210 docking station cable length
Hello,   Before buying the A6210 I would like to know what is the USB3.0 cable length of the docking station ?   Thanks and regards.
  • td47's avatar
    Feb 22, 2017
    Hi, forgot to say, don't forget to dlwonload the latest driver for this, and don't bother with the A6210 genie detection, windows picks it up anway once the driver is installed and it is plugged in. Check your advanced settings, and enable Multimedia & Gaming mode in device manager properties, and possibly disable the sleep mode. Another tip: if installing on to a laptop (like I was) and you already have an active/working WiFi device internally, you will need to disable theat one, in Device Manage, before you can use this external one. Install the latest driver BEFORE plugging it in.
