gmhyman
Jan 05, 2016Guide
A6210 doesn't automatically reconnect after reboot
I have a brand new A6210 running on a windows 10 deskside machine. In general, it works fine, connects to my R7000 router at 5G speeds, etc. One problem - after each reboot, I have to manually r...
JamesGL
Jan 06, 2016NETGEAR Employee Retired
Hi gmhyman,
Try to connect to the network using the windows utility(the icon on the system tray). Make sure that "Connect automatically" is checked before clicking connect.
gmhyman
Jan 06, 2016Guide
Unfortunately I did that (i.e. made sure the "connect automatically" box was checked) long ago. Any other ideas? I suspect some very subtle registry weirdness, but I'm not enough of a registry person to determine if that's true.
- JamesGLJan 09, 2016NETGEAR Employee Retired
Hi gmhyman,
You've mentioned that it also happens on your previous adapter which is a different brand. There might be a setting on the Windows 10 that needs to be configured. Have you tried checking on microsoft team?
- gmhymanJan 09, 2016Guide
I agree it's most probably a Windows setting. I've done google searches, and also had a chat session with Microsoft support which has them changing to generic instead if NetGear drivers, all with absolutely no effect. This isn't a driver problem - if I disable the Ethernet interface and reboot, wifi connects as expected. The issue is detecting and properly handling the second interface. If I knew how to make the wifi primary and Ethernet secondary, I'd make a small wager that the Ethernet wouldn't connect :)
- JamesGLJan 11, 2016NETGEAR Employee Retired
Normally, the Ethernet connection will be prioritize. I am not sure if Windows have option to set the WiFi as primary instead of the LAN.
