gmhyman
Jan 05, 2016Guide
A6210 doesn't automatically reconnect after reboot
I have a brand new A6210 running on a windows 10 deskside machine. In general, it works fine, connects to my R7000 router at 5G speeds, etc. One problem - after each reboot, I have to manually r...
smintz
Jan 11, 2016Aspirant
I have the same problem, although it is an A6200 adaptor connecting to an R6300V2. I had been getting download speeds up to 45Mbps. My ISP after 3 service calls, said I needed a range extender. They installed an R6300EX, still getting 45Mbps. The 4th service call they finally sent a tech that knew what he was doing. He tossed the extender(called “Default-5g_ext”) and instead of the mode being connected to 2.5Ghz, he changed the router to 5Ghz and we were getting up to 240+Mbps.
When he left My default router setting was pointing to the name “default-5G’ and he explained that there was another setting (“default-5g_5ext”) pointing to the range extender R6300V2. On Win 10, I did not previously have the problem with my D-link router. I show 2 modes that my ISP configured. Originally because I was only getting download speed upto 45Mbps, they said I needed a range extender. So, I had them install a 6300EX, but still getting 45Mbps. Finally, a tech came out that knew what he was doing and tossed the extender, reconfigured the mode from 2.4 Ghz to 5 Ghz, I was then upto 240Mbps. Now this referenced problem. He left me with 2 modes called "Default-5g"-(connects at 240+Mbps) and Default-5G_ext"-(connects at 45 Mbps). When I reboot(or sometimes over night with no intervention) it switches back to "Default-5G_ext) at 45. I cannot find the "Default-5g" to even reconnect. How (or can I) get rid of the 5G_ext?
JamesGL
Jan 16, 2016NETGEAR Employee Retired
Hi Smintz,
How many wireless networks do you have?
Can you provide the setup of your network?
Did you set the R6300v2 as the router or an AP?
