AndrewF80
Apr 17, 2016Aspirant
A6210 Driver problem - win 7 freezes
Hey all. Just wanted to let you know I've been experiencing a problem with the A6210 adapter and the latest version of the driver on Win7 Pro 64bit. I had found that when using driver version 5....
AndrewF80
Apr 26, 2016Aspirant
Hi All
So rolling back the driver didn't help after all. The freezes seem less frequent, but every night when I run my photo backup to a network share, my PC freezes. The device was also still unable to start after these freezes.
Running Windows 7 x64.
Have reverted to an old Belkin adapter which is working perfectly, albeit slower. If anyone ever happens to find a solution to this problem, let me know.
- AndrewF80May 27, 2016Aspirant
Saga continues. I'm too stubborn to just go and buy another adapter so I persist with this one.
The latest is I tried updating all the drivers for my motherboard that I thought could be relevant. That is, chipset, and both USB controller drivers. Amazingly, I thought this had resolved the problems. I stress tested the connection using LanSpeedTest and running my backups over the LAN. No crashes and really good performance. I was so happy.
After a few days, the crashes came back again.
I'm testing it on another computer, and it seems to be fine on that one. It's also win 7 64bit but obviously there is something else that's going on that's causing it to crash my original PC.
Are there any logs I can check? It's not even a BSOD so I can't check the crash dump file. The PC just freezes solid. Waiting does nothing. Only a hard reboot brings it back to life.It's so painful!!!
