sheerbot's avatar
sheerbot
A6210.EXE High CPU
Although I don't recall any firmware/dll updates, my A6210.EXE App has been recently running at 30-50% of CPU consistently (no breaks less than 20% ever).  Was there a recent software release which made this happen?  My poor CPU is so busy the fan is always on high, and it's really cramping my gaming....  HELP - is there a solution?  Wait for the next release to fix it?
  • Hello.  It was a Microsoft issue.  Microsoft patches made it run at 20-50% CPU consumption all the time.  Then, yesterday, the latest patch reduced it to 0-2% occasionally.  Thanks if you looked at this....
1 Reply
