OG
Mar 24, 2016Aspirant
A6210 Genie BSoD
I've been trying to get this fixed but I just can't find a solution. My computer has been crashing and the WiFi conenction has been great and then freezes up. I think it's because I have a corrupted d...
- Mar 26, 2016Update: I contacted support and they have helped me uninstall the corrupted driver with REVO Uninstaller. The expert I contacted was very helpful. Afterwards, my wireless connector is running fine... but the BSoD is still happening. I have no idea what the problem is now, but my Netgear product is working fine.
OG
Mar 26, 2016Aspirant
JamesGL
Mar 29, 2016NETGEAR Employee Retired
Hi OG,
Do you any antivirus installed on your computer? If yes, please try to disable it for the mean time to isolate the problem.
