OG
Mar 24, 2016Aspirant
A6210 Genie BSoD
I've been trying to get this fixed but I just can't find a solution. My computer has been crashing and the WiFi conenction has been great and then freezes up. I think it's because I have a corrupted d...
- Mar 26, 2016Update: I contacted support and they have helped me uninstall the corrupted driver with REVO Uninstaller. The expert I contacted was very helpful. Afterwards, my wireless connector is running fine... but the BSoD is still happening. I have no idea what the problem is now, but my Netgear product is working fine.
OG
Mar 26, 2016Aspirant
JamesGL
Apr 10, 2016NETGEAR Employee Retired
Hi OG,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
