bentinar's avatar
bentinar
Follower
Jan 10, 2016
A6210 Genie v1.0.0.34 upgrade process left an entry for v1.0.0.32 in Control Panel
After upgrading the A6210 Genie App to version 1.0.0.34, I still see an entry for version 1.0.0.32 in the Windows 10 Control Panel > Programs > Programs and Features > Uninstall or change a program screen.
I have tried removing version 1.0.0.34 and then removing version 1.0.0.32 and get the following errors:
1. "1605 - This option is only valid for products that are currently installed" when using the Netgear Setup-V1.0.0.32 executable, or
2. "1628: Failed to complete installation" when using the Windows 10 Uninstall function
Has anyone experienced this issue?
Any suggestions?
Thanks in advance.
1 Reply
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi bentinar,
    I was able to successfully uninstall and reinstall the A6210 driver in Windows 10. Can you check with the registry of the computer if it needs to cleaned up.
