Cpollman
Jan 31, 2016Aspirant
A6210 losing internet connection, disabling, causing windows networking functions to crash
I've recently built a new machine which I have been using an A6210 wifi adapter for. Recently, the adapter will lose connection to the internet, and windows networking applications will cease to wor...
Cpollman
Feb 07, 2016Aspirant
I posted this over a week ago. Is nobody going to even acknowledge the issues I've been having?
- JamesGLFeb 10, 2016NETGEAR Employee Retired
Hi Cpollman,
1. Is this the only software that you cannot uninstall?
2. What is the driver version of the adapter that you use to install?
Please try other drivers that can be found in support site.
If you cannot uninstall the adapter, you may need to check the registry of your computer as it may need to be cleaned.
