Windows_10_User
Aug 12, 2016Follower
A6210 Network Adapter name changed after Windows 10 Anniversary Update - Genie App wont open
After installing the Windows 10 Anniversary Update, the Genie App will not open. Device manager shows that the name of the adapter has been changed to "801.11ac Wireless LAN Card". Tried several thin...
JamesGL
Oct 19, 2016NETGEAR Employee Retired
Hi All,
Please PM me your contact info so that I can endorse you to support team.
JamesGL
Community Team
LLWJR
Nov 01, 2016Aspirant
Same issue with A6210 but not sure exactly when it occurred. I haven't been using device but found this issue during a system check. Now using Nighthawk X8 R8500 AC5300. Nonetheless, would like to fix issue. Not being able to open Genie for this device is very annoying as I prefer to know what is working and what is not working on my system and to fix what is not working. Thanks.
- dad_de_oNov 01, 2016Aspirant
FYI, Through this post Netgear gear support contacted me. After we connected over the phone I gave the technician access to my laptop he logged in to the device unloaded the old drivers and loaded a beta version of the drivers. This seems to have fixed the issue, the adapter is now recognized and is working properly. What he mentioned was that during the Win10 update Microsoft loaded a generic set of AC drivers that is not recognized by the system. He also mentioned that Netgear is working with Microsoft to find a fix for this issue. He said they were hoping to have it resolved and a new set of drivers release by the end of November 2016. So now my adapter is working again and I want to thank Netgear for some great customer support even thought my device was out of warranty.
- LLWJRNov 01, 2016Aspirant
Super kind of you to take the time to reply with your update, dad_de_o.
I'll wait for the new driver fix.
I've been using Netgear products for many years because of their quality and support.
- Kb5Nov 02, 2016Aspirant
I have the same problem. My system updated the Netgear driver and after v.1.0.0.35 was installed, Windows could not find the adaptor. Can we download the new beta driver that is working for you?
- dad_de_oNov 02, 2016Aspirant
Try Contacting JamesGL the moderator above with the information he is requesting to see if Netgear can assist with the issue.
