doc_octopus
May 08, 2015Aspirant
A6210 new mediatek driver
Available a new driver on the website of manufacturer of the radio chipset. Also available for download from the site station-drivers.com
xDredgex
May 10, 2015Novice
I've not tested these out yet myself. I spent 30 minutes or so attempting to locate a changelog to no avail. Since I've managed to (in a roundabout way) resolve my USB 3.0 issues, I'll repro that same issue in a VR and try these drivers.
sethm1
Aug 11, 2015Guide
This driver seems redundant if I have A6210 Netgear genie installed.
I ran a Driver Genius scan and this driver (Mediatek RT2870 Wireless Lan Card Driver) popped up to install.
Which I did (is that an oops?)
Do I need it? is it need for my A6210 adapter?
I had a A6200 adapter and this Mediatek Lan Card driver never popped up then.
So this driver is indeed necessary OR I can uninstall it - yes?
Thx
- DarrenMAug 14, 2015Sr. NETGEAR Moderator
Hello Sethm1
It shouldnt be needed if you have the netgear drivers so its up to if you want to keep it or not if its not causing any issues then I wouldnt worry about unistalling it.
DarrenM
- sethm1Aug 14, 2015Guide
Thanks.
Uninstalled.
Doing so did 'break' (probably not the right term) my Adapter - but a reinstall fixed it.
take care/
Oops- meant to add another question (though off topic) - DO I need the A6210 Genie to sit in the Start Up Folder (Start icon/ All Programs/Startup) ?
