AC1200
100 TopicsFailure to Connect (Windows 10)
So using USB tethering I was able to download and install the driver and the NETGEAR genie program for my computer (no CD drive) and everything seemed to be working perfectly, until I tried to connect to my WiFi network. Whether it was through entering the passcode or using "Push n' Connect," the connection attempt failed.3.1KViews0likes1CommentNetgear A6210 internet drops
So, I just got the Netgear A6210 network adapter for Christmas because I was having problems with my old one and it works great but the only problem is I'm getting internet drops randomly for like a second or two and then it comes back. It's hardly noticeable when browsing the net, but when it comes to gaming it can be really frustrating. I have already looked up if anyone else has had a problem with this but have seen nothing. I should note the drivers are updated and I am running the adapter on Windows 8.1. I'm not entirely sure if it's my computer or the adapter, I'm just assuming it's the adapter as the last one I had didn't have this issue. If anyone knows anything that could help I could really use it, thanks.57KViews1like45CommentsAC1200 randomly disconnecting
I'm about at my wits end with this USB adapter, for the last number of days since I picked it up. Pretty much from day 1 it's been randomly disconnecting from my internet, it's still connected to my usb but it refuses to connect to any wifi signal, unplugging it doesn't work, resetting my computer doesn't work, and when it does it lasts about a whole 5 minutes before it's back to square one. I've uninstalled everything for it then reinstalled it. I've used the cd download, and the download on this website but still nothing is working. I'm running on windows 10 and see a lot of these problems come from people using windows 10. Is there any fix for this? These things aren't cheap and to have it not work is infuriating. Thanks7.4KViews0likes4CommentsAC1200 Choppy connections, Had N600 Dual-Band, was fine
Well I had a WNDA3100v2 – N600 Wireless Dual Band USB Adapter before and it crapped out on me. Looks like it just went dead from years of use. I went to the store and bought the current model that I'm using, the AC1200, I started to experience choppy connections online while gaming. The N600 was fine, no connection issues and only slowed down if other people were heavily using the net. Now my ping time in game is 10-20ms but i'm experiencing spikes where the connection is choppy. I look and I see no fluctuation of ping. Streaming videos is fine, downloads are fine. I installed the new drivers without the genie right off the bat and it was spiking. I then installed the genie to see if it would fix it. Did not work. Reset the router. Still spiking. I'm about to go return it. It seems like it's a hardware issue, weird how the lesser model outperforms.3.4KViews0likes1CommentA6210 operating @ High Speed (USB 2.0)
I've installed A6210 using the standalone Windows 7 driver, and on every boot I receive the W7 message informing me that the device will perform faster when using a SuperSpeed (USB 3.0) port. It is attached to a USB 3.0 port, but on running USBTreeView, I found it to be registered under one of the EHCI hubs and running at USB 2.0 speed. I have two other USB 3.0 capable devices, a flash drive and a drive dock, both of which, when attached, are registered to the USB 3.0 hub and run at SuperSpeed (&, naturally, no W7 message telling me they can perform better etc.) I've tried all three devices in all USB 3.0 ports, both front panel and rear m/b ports, and the A6210 is the only device not running at SuperSpeed. o/s: Windows 7 Pro SP1 x64 auto-updated m/b: GA-Z87-HD3 (Gigabyte) bios: AMI F6 (last to address USB issues) usb: Intel XHCI & Root Hub On another PC, with an Asus board & NEC/Renesas drivers, the A6210 runs @ SuperSpeed. Any ideas would be appreciated.Solved70KViews0likes42CommentsSteam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
So, I paid 60 dollars for this, lol. I have the latest drivers, etc. When I try to download ANY game on Steam, it says that the file is corrupt, etc. Verifying the integrity of the game cache will NOT work. Please help!!!!!16KViews0likes29CommentsA6210 - No Adaptor Detected
Hi All, Thanks in advance for my issue. I just purchased A6210 and has been trying to install it for hours without success. The issue is genie will not detect the adapter at all. When I check under device manager, the driver does appear to be installed. but the status is as below: This device is not working properly because Windows cannot load the drivers required for this device. (Code 31) {Operation Failed} The requested operation was unsuccessful. I have tried to remove/install again and again, restarting computer in between, clean registry, etc. Nothing has worked. Can anyone please give me any suggestions? Is this adapter faulty?? Thanks, Anthony18KViews0likes5Comments
