BokuNoPico
Jun 17, 2015Aspirant
Steam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
So, I paid 60 dollars for this, lol.
I have the latest drivers, etc.
When I try to download ANY game on Steam, it says that the file is corrupt, etc.
Verifying the integrity of the game cache will NOT work.
Please help!!!!!
- FairytailVirtuosoHave you tried to download using a different computer?
- BokuNoPicoAspirant
minions08 wrote: Have you tried to download using a different computer?
It's not my computer.
I tried a Linksys usb adapter, it downloaded games perfectly fine.
However, the netgear one is fast, so please! :( - chiruno09Aspirant
Hi!
I had the same problem, just take it off the stand and plug it directly into the computer. Worked for me at least, hope this helps.- aloonjAspirant
chiruno09 wrote:Hi!
I had the same problem, just take it off the stand and plug it directly into the computer. Worked for me at least, hope this helps.I read this on the Steam discussion forums also (perhaps it was you). I shall try directly connecting and report back. This issue is 100% repeatable with my A6210 and Steam downloads.
Cheers,
A
- aloonjAspirant
aloonj wrote:
chiruno09 wrote:Hi!
Cheers,
A
Just reporting back: Made no difference to my problem :(
- rafitamolinAspirant
Please Netgear, I really need a fix for this now, it's getting so annoying and I can't download anything on Steam.
- aloonjAspirant
Try switching to 2.4Ghz from 5Ghz?
My router has only 2.4ghz, can't do that.
- Bruno33Aspirant
Hello,
I have the exact same issue. Tried everything :
- Different USB ports 2.0 and 3.0 (even a totally isolated 2.0 "gaming" port for high end mouses)
- 5 GHz and 2.4 GHz (my 5 GHz is the only one in the area)
- Muldimedia/Gaming on and off
- latest drivers
- QoS and video stream on and off on my router (Netgear also)
I think this is pretty annoying : all my big zip download are corrupted, steam downloads always stop.
When I kill Skype, 95 % of the download are OK... If this can help...
- Bruno33Aspirant
OK seems that I got the solution.
After having tried everything (with and without the USB base, different USB ports, all driver configuration possible...etc)
I found that the problem was very simple : the antenna.
I came back to my initial configuration. Same USB key position, with the USB base.
I just unfolded the antenna to its max position => 100% download are now clean and OK !
Same position with antenna folded on the key => I had the SAME reception quality (constant 300 Mbps), but download where all corrupted.
Incredible but true for my case.... ! (tested and restested with dozens of Android ROM downloads with md5 check)
- vincegouhAspirant
My usb adapter was already unfolded but it doesn't work :(
