BokuNoPico
Jun 17, 2015Aspirant
Steam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
So, I paid 60 dollars for this, lol. I have the latest drivers, etc. When I try to download ANY game on Steam, it says that the file is corrupt, etc. Verifying the integrity of the game cach...
aloonj
Jan 29, 2016Aspirant
Try switching to 2.4Ghz from 5Ghz?
rafitamolin
My router has only 2.4ghz, can't do that.
- JamesGLJan 31, 2016NETGEAR Employee Retired
Hi aloonj,
Do you have any updates from the support team?
Hi rafitamolin,
Do you have other devices that can performs well with steam download?
How far is the computer(with A6210) from the router?
Try changing channels of the 2.4Ghz as it might be a network interference with other wireless network.
- aloonjJan 31, 2016Aspirant
Support did some testing to try and recreate my issues and decided that the issue was interferance on 5Ghz. I swapped to 2.4Ghz and seemed much better..
However, I have tested alternate WiFi adapters at 5Ghz from same location and have no issues, so I am not fully convinced the problem lies with interference in my home.
I spoke too soon!
Prompted by this latest forum post, I decided to try downloading again via Steam now that I am permanently on 2.4Ghz, but no, it has once again stopped mid download, I keep re-trying and eventually Steam reports the download is corrupt.
I will reopen my case and inform support.
[EDIT]
It seems my case has been closed and I cannot re-open it. At this point I think it will just be easier buying an alternate adapter.
