BokuNoPico
Jun 17, 2015Aspirant
Steam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
So, I paid 60 dollars for this, lol. I have the latest drivers, etc. When I try to download ANY game on Steam, it says that the file is corrupt, etc. Verifying the integrity of the game cach...
Bruno33
Apr 01, 2016Aspirant
Hello,
I have the exact same issue. Tried everything :
- Different USB ports 2.0 and 3.0 (even a totally isolated 2.0 "gaming" port for high end mouses)
- 5 GHz and 2.4 GHz (my 5 GHz is the only one in the area)
- Muldimedia/Gaming on and off
- latest drivers
- QoS and video stream on and off on my router (Netgear also)
I think this is pretty annoying : all my big zip download are corrupted, steam downloads always stop.
When I kill Skype, 95 % of the download are OK... If this can help...
Bruno33
Apr 04, 2016Aspirant
OK seems that I got the solution.
After having tried everything (with and without the USB base, different USB ports, all driver configuration possible...etc)
I found that the problem was very simple : the antenna.
I came back to my initial configuration. Same USB key position, with the USB base.
I just unfolded the antenna to its max position => 100% download are now clean and OK !
Same position with antenna folded on the key => I had the SAME reception quality (constant 300 Mbps), but download where all corrupted.
Incredible but true for my case.... ! (tested and restested with dozens of Android ROM downloads with md5 check)
