BokuNoPico
Jun 17, 2015Aspirant
Steam downloads corrupt?! (Using A6210 USB Wi-Fi Adapter)
So, I paid 60 dollars for this, lol. I have the latest drivers, etc. When I try to download ANY game on Steam, it says that the file is corrupt, etc. Verifying the integrity of the game cach...
chiruno09
Nov 04, 2015Aspirant
Hi!
I had the same problem, just take it off the stand and plug it directly into the computer. Worked for me at least, hope this helps.
- aloonjNov 21, 2015Aspirant
chiruno09 wrote:Hi!
I had the same problem, just take it off the stand and plug it directly into the computer. Worked for me at least, hope this helps.I read this on the Steam discussion forums also (perhaps it was you). I shall try directly connecting and report back. This issue is 100% repeatable with my A6210 and Steam downloads.
Cheers,
A
- aloonjNov 25, 2015Aspirant
aloonj wrote:
chiruno09 wrote:Hi!
Cheers,
A
Just reporting back: Made no difference to my problem :(
- JamesGLNov 28, 2015NETGEAR Employee Retired
Hi All,
Just to verify if the computer you are using is on Windows 10.
