Casualuser
Dec 07, 2016Follower
A6210 "No internet access" no valid IP configuration
Using A6210 wireless adapter to connect to a netgear wireless router. Was working fine, suddenly "No Internet access." When using the Troubleshooting function, computer says it's resetting the wifi ad...
NelsonMiller22
Dec 21, 2016Aspirant
Hello, here are some successful tips you can follow to get a valid IP configuaration. I hope this helps you resolve the issue.
http://vkrepair.com/wifi-doesnt-have-a-valid-ip-configuration/
bigfatron
Dec 21, 2016Tutor
NelsonMiller22 wrote:Hello, here are some successful tips you can follow to get a valid IP configuaration. I hope this helps you resolve the issue.
A solution to a slightly different issue unfortunately.
