Morphius's avatar
Morphius
A6210 No longer connecting to 5G (Windows 10 Home Edition 64-bit)
My ASUS computer got an update to the NetGear drivers via Windows Update.  Now, I am no longer able to connect to my 5G network.  I CAN, however, connect to the 2.4G network just fine.  All my other ...
  • Morphius's avatar
    Oct 19, 2016
    This answer, from a different thread, just solved my problem...
    I have solved the problem.
    1. Open up the Windows 10 Device Manager
    2. From the list open Network Adapters  -  Select and right click on 802.11ac Wireless LAN Card
    3. Select "Update Driver Software" and click
    4. Select “Let me pick from the list of drivers on my computer”
    5. Select the Netgear A6210 WiFi USB3.0 Adapter
    6. Then click next
    7. The driver will now re-install and you should see the message "Windows has successfully updated your driver".
    This is how I solved my problem and I can now see my 5GHz SSID and connect to it
