Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
JamesGL
Oct 11, 2016NETGEAR Employee Retired
Hi Ilovegamimg,
1. What is the driver version you use to install the adapter?
2. Can you see the adapter in Device Manager?
JamesGL
Community Team
