Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
JamesGL
Oct 17, 2016NETGEAR Employee Retired
Hi Ilovegamimg,
If it is not being detected under device manager, please try plugging it on a different computer and check if it is being detected.
JamesGL
Community Team
Ilovegamimg
Oct 18, 2016Aspirant
- JamesGLOct 19, 2016NETGEAR Employee Retired
Hi Ilovegamimg,
Please check if the adapter under device manager shows "802.11ac Wireless LAN Card" if you put it back to the Windows 10 anniversary update.
JamesGL
Community Team
- IlovegamimgOct 19, 2016Aspirant
Now it does after i downgraded a windows 10 update, before that it didnt.
